Subject: Re: Face frame overlap for integral inset drawers
5/9/23
Justin Belcher
I am planning a cabinet build that calls for integral drawer fronts (half blind dovetails) with undermount drawer slides. Because the drawer front is integral, it'd be desirable for the face frame to conceal the drawer hardware and give the appearance of a traditional fine furniture drawer.
My question is whether having a tight reveal around the drawer box itself (3/32 or 1/8) will interfere with the undermount drawer hardware. BLUM is my likely choice here but open to other suggestions.
And yes, this will be a tricky build compared to false front inset drawers. Just looking for opinions on nailing the build as specced.
5/9/23       #2: Face frame overlap for integral ins ...
The only real difference will be the placement of the drawer slide. You don't need to compensate for the thickness of the drawer front.
I don't see any real challenges in this. But I'm use to doing inset cabinets.
If you use the Blum slides you will need to use the inset locks that have the in/out adjustment.
5/10/23       #4: Face frame overlap for integral ins ...
I agree with Leo.
5/10/23       #6: Face frame overlap for integral ins ...
andy
i've done this and the side clearance wasn't an issue with seeing the hardware, but the bottom of the drawer did show the slides. we fixed this by creating a swoop on the sides and and front. if you look at the instagram account of gardehvalsoe you can see how they do it. they swoop the sides as well but i dont think its necessary
5/10/23       #7: Face frame overlap for integral ins ...
Justin Belcher Member
Thanks all. Glad to know it's mostly as straightforward as any inset drawer. I'll start mocking some things up to test.
I like the swoop idea adam. Thanks for the reference link. I'm assuming that gets paired with some setback of the drawer slides? I've seen an article in Fine Woodworking that suggests using a 5/8" spacer block between the drawer front and the undermount mechanism (i'm assuming that's to account for the lack of a drawer box front behind the applied front), and offsetting the slides behind the face frame by about 1/8"
5/10/23       #8: Face frame overlap for integral ins ...
I can't imagine a homeowner will know if that drawer front is 3/4" thick of 1" thick. Make the false front 1/2" thick and glue to the box with a single line of glue on the center so the wood can still move. Either way, not a challenge to do.
    • Better Vacuum Cups, Inc.
    • Biesse America
    • CP Adhesives
    • Impact Search and Placement
    • Template Services
