Subject: Re: Wide belt sanding life
5/12/23
Brandon Member
How long should a wide belt sander last on a Homag sander with a chevron belt? It seems I’m getting about 40,000 linear feet on each of my belts before they are worn out. Is that normal?
5/12/23       #2: Wide belt sanding life ...
Lineal feet? You can get miles of that if the stock is 2" wide.
5/13/23       #3: Wide belt sanding life ...
mike
dont know anything about the sander . but old timer told me to rotate the belt each day i use sander & the belt life will go much further.
5/16/23       #4: Wide belt sanding life ...
Chris Member
Most of the belts we use are directional... Are the belts wearing out or clogging up. We have used that pink liquid stuff & rinse with water to get the wood resin to dissolve from the belt.
5/17/23       #5: Wide belt sanding life ...
pete Anderson
There is a cleaner made for cleaning resin from sanding belts, it is called ABC abrasive belt cleaner. There is also a solvent that takes resin off that is made for graffiti cleaning that works on resin called TSW, this stuff works, sold at paint stores. Spray, then use a stiff bristle brush to clean resin off sanding belts.
I find that the grit lasts a lot longer when the belts are cleaned.
6/20/23       #6: Wide belt sanding life ...
Adam West  Member
Cleaning an abrasive belt that had worn is not only a waste of time, it also destroys stain color consistency. Using a dull belt closes the wood and opening it back up with an orbital sander is inefficient and inconsistent.
I cannot give a lineal foot number because life time is dependent on the amount of stock the belt is removing along with the toughness of the material being sanded.
    • J&P Machines
    • CabMaster Software
    • Lignomat
