Subject: Re: Scm k360
Scm k360
6/22/23
Tony
Hi my Scm olimpic k360 is scraping when I edge doors with hinge holes and the floaters are to the top side, how should I adjust or what should I adjust this only happens when doors normal flat surface boards are perfect.
6/28/23       #2: Scm k360 ...
Oggie  Member
I suppose the guide roller for the scraper assembly that normally rides on the surface of the board and determines the position of the scraper knife relative to the surface of the board is falling into the hinge hole and guides the knife deeper, or the knife just surfs on its own on the surface of the board while the guide roller is in the hole.
I assume you are cutting boards and drilling hinge holes on a CNC, otherwise I see no reason why would hinge holes be drilled before edgebanding.
Maybe you could make some round pegs that will fit perfectly into hinge holes and use them to plug the hinge holes before edgebanding and take them out when finished (maybe with a magnet).
