Subject: Re: Custom Kitchen Magnet Paint
7/7/23
Troy Beverly
Website: http://iwswoodworking.com
Hello all,
Need some advise on custom high end kitchen fridge panels.
Designer calls out for fridge panel to be painted with magnet paint, which to the best of my knowledge can't be any color or sheen I choose. Is there a way to prime with magnet paint and still be able to finish paint with kitchen color and product ( Ben Moore Advance ) and still have good magnetic strength? Has anyone used a strong magnetized primer then full topcoating and had decent magnet strength?
Everything I read says 1 or 2 light coats is possible but reduces magnetic strength. My goal is to have a magnetized fridge panel that has the exact finish as the rest of the kitchen. Another thought was do they make thin magnetized sheet goods that i could apply to the back of my 5 piece fridge panel and all the strength would pull through my Medex panel.
7/7/23       #2: Custom Kitchen Magnet Paint ...
Josh Koschak
Could you use steel panels in your frame and paint with conversion varnish or 2k poly? Heavy yes, but they get mechanically fastened to the heavy fridge door anyway.
7/8/23       #3: Custom Kitchen Magnet Paint ...
bob lee
formica has a magnetic / markerboard laminate
also magnetic sheet which can be used under standard laminate
7/12/23       #5: Custom Kitchen Magnet Paint ...
FGT CABINETRY LLC (IOWA) Member
Website: https://fgtcabinetry.com/
Here are some things to consider when choosing custom kitchen magnet paint:
The type of paint: There are two main types of paint that can be used for custom kitchen magnet paint: magnetic paint and chalkboard paint. Magnetic paint is specifically designed to attract magnets, while chalkboard paint is designed to be written on with chalk.
The color: The color of the paint will depend on your personal preference. You can choose any color that you like, but it is important to choose a color that will complement the other colors in your kitchen.
The finish: The finish of the paint will also depend on your personal preference. You can choose a matte finish, a semi-gloss finish, or a gloss finish.
The durability: The durability of the paint will depend on the type of paint that you choose. Magnetic paint is generally more durable than chalkboard paint.
