Subject: Re: Beveled fingerpull
Beveled fingerpull
7/12/23
Chris
Once again I'm being asked to have a back beveled fingerpull on stain grade material (grain matched 3/4" MDF Rift White Oak in this case) . Is there a machine for this? We are a small custom shop.
In another forum someone mentioned a Festool Contouro
Here's the slow method we've come up with:
1. Back bevel veneered door
2. hand apply Titebond 1 to 1MM banding and edge of door, wait for it to dry (ish),
3. hand iron on
4. Trim excess with a chisel or flush rout...by hand
We've tried :
Applying solid square banding but clamping a bevel requires some special clamping attack which we've not been able to refine to the point of a repeatable/consistent outcome. We did try cutting a flat on top of both the door and the mating wood banding, but that crept and tilted under pressure of clamps as well. Using cauls seems too time consuming/clunky and the glue squeeze out under the cauls makes me a little nervous cuz cleanup (Oak turning black, etc)
Gluing on square, solid stock and then back beveling interrupts grain pattern so no fly zone there
I believe contact cement is still (in this modern age) a no fly zone (correct me if Im wrong)
Im sending my guy to the AWFS fair in a couple weeks. Maybe he will find a method there.
Outsourcing = no control over grain matching
Thank you for any responses
7/12/23       #2: Beveled fingerpull ...
Thomas Gardiner
How about a 5/8" x 5/8" rabbet into the pull edge. Glue and flush a solid piece into the rabbet. Edge band all around. Work the 45° finger pull.
The remaining 1/8" will keep face grain continuity. Cut the solid stock to give rift figure when routing the 45.
View higher quality, full size image (2976 X 2976)
7/12/23       #3: Beveled fingerpull ...
Chris
Brilliant! I have no idea why we didn't think of that. We just tried it and it looks good, though I wonder about the 1/8" wide edgebanding (where left square) Could be prone to flaking off. After all, it is a "finger" pull.
Thanks Thomas!
7/13/23       #4: Beveled fingerpull ...
Eddie
We band all 4 sides, bevel and add a piece of veneer to the bevel cut with veneer glue. Cut the excess, sand, done. been doing that for years.
7/13/23       #5: Beveled fingerpull ...
Chris
I guess that little 1/8" wide banding on the flat is holding up to fingers. Makes me suspicious though.
Forgive me but what is "veneer" glue? How do you apply the veneer to the bevel?
Thanks again
7/14/23       #6: Beveled fingerpull ...
Eddie
We use 1'' material when doing finger pull, so the top is 1/4''. when you bevel the 45° and apply the veneer, it covers the exposed edge so the fingers won't pull the veneer.
We use Better Bond X-Press Veneer glue.
We clamp the veneer on it, vacuum press in the past as well.
Gotta be creative!
View higher quality, full size image (1164 X 1345)
    • Steve H. Wall Lumber Co.
    • RT Machine Co.
    • Limtech Industries, Inc.
    • CP Adhesives
    • ECabinet Systems
    • Palmetto Cabinet Doors
    • Anver Corporation
