Subject: Re: Setting up a Blum Minipress for tall doors
8/13/23
Mike  Member
I have a Blum minipress which we've been using for a while. It's setup with the short main fence on a 42" wide table. I have the stops set for the top and bottom hinges but for the middle hinges on tall doors we just measure and mark the location and drill by sight. Are you guys setting stops for middle hinges?
I'm asking because I am moving into a larger shop and am considering setting the Minipress up on an 8' table so that the fence extensions can be installed. However, I'm now wondering if they're necessary.
I've only used the Minipress for drilling/pressing hinges and for boring for Metaboxes. Are there any other common boring operations that would utilize the long fences?
8/13/23       #2: Setting up a Blum Minipress for tal ...
With the adjustment in the hinges, you don't need to hit dead perfect on locations. But if you are doing a half dozen long doors a day, I'd set stops. Quantity makes the decision.
8/14/23       #4: Setting up a Blum Minipress for tal ...
Mike  Member
Makes sense. I don't usually do a large quantity of tall doors so I think I'll just set the machine up with the main fence on a 3' or 4' wide bench. However, I'll keep the fence extensions handy so I can install them if/when I end up with a job that has more than a just a few tall doors.
8/18/23       #5: Setting up a Blum Minipress for tal ...
I have mine set up with the extension fences and 8 stops all set for different standard door sizes, I drill the holes with a line boring machine. so I never have to measure it speeds up production considerably
8/21/23       #6: Setting up a Blum Minipress for tal ...
Bruce H
I have fence extensions on each side of the mini press with stops set. For the most part I drill tall doors in the same location for every door almost without exception. First hinge is 94 1/2mm from each end and the second hings is 702 1/2" from each end. I never drill for a three hinge door, too hard to figure out where it is.
