Subject: Re: Painted Slab doors
Painted Slab doors
8/25/23
MB
What are you doing for painted slab doors? MDF with banding? MDF with solid edges? Or?
8/25/23       #2: Painted Slab doors ...
Robb Parker  Member
Just MDF, Plum Creek or equal, no edges.
8/25/23       #3: Painted Slab doors ...
duster
For mdf doors, after routing and sanding the edges, we brush on a coat of glue size (titebond mixed with water) on the edges. After it dries in about an hour, sand the edges lightly with 220 grit. This seals the edges so they don't absorb paint. After primer and paint, we get edges as smooth as the faces.
8/25/23       #4: Painted Slab doors ...
Leo G
Edgeband with 1mm Maple, way quicker than glue sizing and provides a little more protection than just the MDF itself. Provides a smoother surface that's easier to paint than sanded Plum Creek.
8/28/23       #5: Painted Slab doors ...
Jim Kolar
We use HDF range platinum. Very dense panel. We sand edges after cnc and 1/8" round over on edge hand sand the 1/8" round over. Holds primer very well and no bleed through of mdf.
8/29/23       #6: Painted Slab doors ...
Bob
Website: https://www.liverpoolglazing.co.uk/
With mdf doors, after routing and sanding the edges, we paint on a coat of glue size (titebond mixed with water) on the edges. This really helps, what do you guys do?
9/1/23       #7: Painted Slab doors ...
I'm not sure glue size is an improvement over just a good quality primer/sealer like a BIN shellac or a 2 pak catalyzed primer. The glue sounds like a messy waste of time.
9/6/23       #8: Painted Slab doors ...
Pdub
We glue size. Depending on MDF, it can take multiple coats of primer/ sealer (no matter how good) to seal edges. Glue size with a hot dog roller is fast.
Found that 1 mil edgeband will always show that line under paint eventually.
We've also had bad experience with HDF warping on bigger pieces so stopped using it
9/14/23       #9: Painted Slab doors ...
Matt
We route and edgeband them with 1mm maple. It's not the cheapest option in terms of materials, but when you consider that they come off of a properly setup edgebander with a nice small radius on it, consistently on every door, and the finish booth won't be blowing time fighting the fuzzy MDF, it's worth it.
We've experimented with just painting the edges without edgeband and they still look fine, really, but you have to spend a bit more time sanding them and you definitely have to spend time putting some sort of profile on it, or easing the edge by hand. I've never found that more economical than letting the bander put on 1mm maple, as long as you have a good bander and a good tech who won't do stupid crap like leave a huge lip on the band and assume "well the finish booth can sand all that out".
9/14/23       #10: Painted Slab doors ...
Leo G
I've never had a crack form at the edge/band junction unless there was a defect in my application.
