Subject: Re: lamello zeta
lamello zeta
10/15/23
John B Member
Website: http://woodmanseewoodwrights.com
I do probably 95% face frame style cabinetry and have for 45 plus years. When the seldom occurring job comes up that needs frameless I have just drilled and screwed my boxes together. I am normally using 3/4 pf maple plywood for all our boxes. I have a couple large projects coming up that are frameless and contemplating buying the Lamello zeta tool and using either the lamex or tenso inserts to assemble the boxes. I don't have a cnc or a construction borer so thinking this might be a good alternative. Anyone else utilizing this method and if so any feedback? Seems like a good excuse to buy a tool that looks pretty sweet :) !
10/15/23       #2: lamello zeta ...
I think you could make jigs and offset boards for placement to make it work efficiently enough.
I have one. Bought it for one specific task a few months ago, haven't used it since. I want it to be used when it makes sense, but I don't want the guys using it any opportunity, because while useful, the fittings are expensive and it's not real fast.
I've never used it for boxwork.
It's similar to biscuits or dominos. When it's right, it's right. The rest of the time it's just too slow for what you achieve.
10/15/23       #3: lamello zeta ...
I've made hundreds of boxes using just the biscuits. I recently bought a new British system to do some knock-down pieces. It's considerably cheaper than Lamello. Free shipping to US from Axminster Tools in England.
https://www.intelligentfixings.com/products/peanut-2
10/17/23       #4: lamello zeta ...
Chris H
Website: https://www.csaw.com/lamello/
Good morning,
The P-System is a very versatile system for both face frame installation and cabinet box construction. It's especially useful for large cabinet boxes needing to be delivered and assembled on-site or for finished end panels. *Using them for cabinets with concealed end panels (where they could otherwise be screwed together) would be overkill in most instances. You may want to browse the Lamello Lessons YouTube channel I've linked here if you decide to buy a new Zeta - it'll help show you a lot of the things you can do with it. I've also attached our face frame application card for reference. Many customers flat-finish their face frames and install them with Clamex or Tenso connectors on the cabinet box, on site. Eliminates masking and unmasking of the cabinet boxes and improves finish quality on the face frames.
P_System_face_frames.pdf
https://www.youtube.com/playlist?list=PLZpugdMsywoYvNUe48ArOsX6mT3tlhbws
10/23/23       #5: lamello zeta ...
I love the Lamello zeta, however the fasteners are very expensive so like Karl mentioned, you have to be careful of how you use it or you will soon find it harder to be competitive.
10/24/23       #6: lamello zeta ...
Quicktrim
The tool is a huge help where needed.
Speeds up panel installation for us immensly. We use it here and there and find that we might go through 300 fasteners in a month and then for the next three months use 10. So it comes and goes.
I will say that thre cost of the fasteners never bothered me as when used it was serving a purpose that samed a ton of time and we do our boxes with dowels and cse clamp so we are using it only where needed. I find them to be very fast and a great install aid. Also occasional use in the shop. For me install time saved is where it really shines.
In pic we used zeta to connect all shelf units on site super fast and easy with no visible fastener.
View higher quality, full size image (987 X 813)
    • J&P Machines
    • CabMaster Software
    • Lignomat
