Subject: Re: Biesse service technician
11/25/23
Jim Herron
Does anyone have a Biesse technician they can recommend near the Dallas Texas area
I have a Rover A4 that will not start and initialize global homing
Thanks Jim
11/28/23       #2: Biesse service technician ...
I'm not a tech and I'm not in Dallas, but I've had many Biesse's and the symptoms you describe are usually the e stop circuit.
If you have a wiring diagram and an electrician friend maybe you can figure it out.
11/30/23       #3: Biesse service technician ...
Jim Herron
Turns out my original computer had some blown capacitors on the motherboard.
Fortunately I got a 2022 Biesse backup computer from the original owner.
I had my computer guy move the drive cards to the new computer and reinstalled it in the enclosure.
Started, homed and ran perfectly, but randomly threw a blue screen error that froze Biesse Editor and disabled the machine tool configuration.
Biesse tech worked with me off/on over a few days and narrowed the problem down to a usb wireless internet adapter.
After having me use a wired ethernet cable connected via a usb/ ethernet adapter the issue seems resolved.
The Biesse support tech explained that the 20 yr old hardware (built in ethernet card) wasn't recommended for direct ethernet connection and that on even a "new" Windows XP computer build, Biesse recommends a wired internet connection using a usb/ethernet adapter and just bypass the built in card.
I must say the support tech I got was very thorough, knowledgeable and professional
I bought this Biesse Rover after a fire destroyed my Weeke pod and rail.
The Weeke support from Stiles was A+ and the Biesse support service is every bit on par once I connected with a compatible representative
11/30/23       #4: Biesse service technician ...
Jim Herron
Dropout-
When I had the machine installed in the shop, there was an issue with the 24 volt E circuit
I loaded, transported, and did the preliminary installation and the installation tech isolated the problem to one of the 24volt contactors and jump wired it so I would be able to use the machine until a replacement contactor arrived.
It did disable the mushroom and cable E stop when jump wired.
Not a huge deal as I an the sole operator, however,
I have a technician scheduled to install the low voltage contactor and insure the E stops functional.
Thanks for the reply.
    • Original Saw Company
      Industrial Radial Arm Saws
    • Country Saw & Knife
    • GreCon
    • Steve H. Wall Lumber Co.
