Subject: Re: Biesse service technician
11/25/23
Jim Herron
Does anyone have a Biesse technician they can recommend near the Dallas Texas area
I have a Rover A4 that will not start and initialize global homing
Thanks Jim
11/28/23       #2: Biesse service technician ...
I'm not a tech and I'm not in Dallas, but I've had many Biesse's and the symptoms you describe are usually the e stop circuit.
If you have a wiring diagram and an electrician friend maybe you can figure it out.
11/30/23       #3: Biesse service technician ...
Jim Herron
Turns out my original computer had some blown capacitors on the motherboard.
Fortunately I got a 2022 Biesse backup computer from the original owner.
I had my computer guy move the drive cards to the new computer and reinstalled it in the enclosure.
Started, homed and ran perfectly, but randomly threw a blue screen error that froze Biesse Editor and disabled the machine tool configuration.
Biesse tech worked with me off/on over a few days and narrowed the problem down to a usb wireless internet adapter.
After having me use a wired ethernet cable connected via a usb/ ethernet adapter the issue seems resolved.
The Biesse support tech explained that the 20 yr old hardware (built in ethernet card) wasn't recommended for direct ethernet connection and that on even a "new" Windows XP computer build, Biesse recommends a wired internet connection using a usb/ethernet adapter and just bypass the built in card.
I must say the support tech I got was very thorough, knowledgeable and professional
I bought this Biesse Rover after a fire destroyed my Weeke pod and rail.
The Weeke support from Stiles was A+ and the Biesse support service is every bit on par once I connected with a compatible representative
11/30/23       #4: Biesse service technician ...
Jim Herron
Dropout-
When I had the machine installed in the shop, there was an issue with the 24 volt E circuit
I loaded, transported, and did the preliminary installation and the installation tech isolated the problem to one of the 24volt contactors and jump wired it so I would be able to use the machine until a replacement contactor arrived.
It did disable the mushroom and cable E stop when jump wired.
Not a huge deal as I an the sole operator, however,
I have a technician scheduled to install the low voltage contactor and insure the E stops functional.
Thanks for the reply.
5/21/25       #6: Biesse service technician ...
Youness Benzakour
Dear Team,
I hope this email finds you well. I am reaching out to report an issue with our SELCO EB80 machine, purchased in 2004, and to seek your technical assistance. Below are the machine's specifications for your reference:
Machine Specifications:
Model: SELCO EB80
Serial Number: 36736
Year of Construction: 2004
Air Supply: 7 BAR
Suction Flow Rate: 30 m/sec
Weight: 3950 kg
Power Supply Voltage: 380 VAC
Rated Current: 36 A
Number of Power Supply Phases: 3
Power: 19 kW
Frequency: 50 Hz
Circuit Capacity: Suitable for circuits delivering up to 10 kA RMS sym at the power supply voltage
Issue Description:
During routine checks, we identified a problem with the analog output A01, which controls the speed of the pusher during its movement. The output voltage of this analog channel is unstable and fluctuates, causing irregular displacement and noticeable vibrations in the pusher motor.
Technical Details:
The output voltage of analog channel A01 fluctuates between 0.67 V and 0.58 V during the pusher's movement.
This fluctuation leads to inconsistent movement and vibration of the pusher motor.
Actions Taken:
We performed a thorough inspection of the machine, including the drive and other related components.
All checked components appear to be functioning correctly, and no faults were detected.
The issue seems isolated to the HSD P250A analog output card, but we are unsure if this card needs to be replaced or if further troubleshooting is required.
Request for Guidance:
We would appreciate your input and expertise in resolving this issue. Specifically:
Are there specific tests or diagnostics you recommend to confirm if the issue lies with the HSD P250A analog output card?
If the card requires replacement, could you confirm the appropriate replacement part number and availability?
Could improper calibration of the analog output cause this issue? If so, how should we proceed to recalibrate the system?
Are there any software updates, settings, or parameters we should review or adjust to stabilize the analog output?
Could you provide a troubleshooting guide or diagnostic checklist specific to this issue?
Is it possible that environmental factors (e.g., temperature, vibration) could cause the fluctuation?
Could this issue be related to an electrical interference or grounding problem?
Additional Support:
If necessary, we are happy to provide additional data, photos, or videos to assist with diagnostics.
We look forward to hearing your insights and appreciate your assistance in resolving this issue promptly. Please let us know if there is anything further we can do from our end to support the troubleshooting process.
Thank you for your time and expertise.
