Subject: Re: Special Hinge to open cabinet to clear oven handle
12/20/23
John
The appliances were recently replaced, and the cabinet cannot open because it hits the oven handle. The cabinet works in the way you open the doors, and the drawers roll out. As you can see in the pics, the handle gets in the way. Before the suggestions start flowing in, replacing the oven/handle/moving it, etc, is not an option. Replacing the entire cabinet is not an option. I am looking to see if there is a custom hinge that will "bow/flex" away to allow the door to open all the way.. I'm not concerned with matching hinges, but just need the door to open to roll out the drawers. The only other option to explore is to change the inside drawer system, but again, I think it would require a special hinge to clear the handle.
View higher quality, full size image (4000 X 1848)
12/20/23       #4: Special Hinge to open cabinet to cl ...
D Brown
Modify the roll out, make it narrower on that one side. Or modify the end of the oven handle ?
12/22/23       #6: Special Hinge to open cabinet to cl ...
Paul
John, What's the overlay on that door on the hinge side? (distance from the left edge of the closed door to the inside of the cabinet opening)
Are you a cabinet guy with access to a cabinet shop?
1/5/24       #7: Special Hinge to open cabinet to cl ...
Brad
It's wonky, but you could remove the left door from the cabinet and then hinge it to the right door and have it operate like a bifold door.
1/5/24       #8: Special Hinge to open cabinet to cl ...
Jim Herron
Brad, you have the thinking cap on...good call
