Subject: Re: Salice restricter clip for 110 degree soft close hinge
12/13/23
Al
I’ve used these before but Hafele has them listed for 105 degree not 110 degree. Frameless style hinge with soft close. Need item number.
Thanks,
Al
12/14/23       #2: Salice restricter clip for 110 degr ...
Hi Al,
The same clip is used for both the 105 degree and the 110 degree Silentia+ hinges. It limits the angle to 86 degrees.
Item: S1E637XY
Regards,
Dennis bean
Salice America
12/14/23       #3: Salice restricter clip for 110 degr ...
This is the clip.
View higher quality, full size image (484 X 415)
12/14/23       #4: Salice restricter clip for 110 degr ...
Al
Thanks always Dennis.
12/14/23       #5: Salice restricter clip for 110 degr ...
Al
Dennis,
Hafele seems to be out of the 110 soft close hinge with dowels. They only have screw on version. This situation is last couple of times I have ordered. Is there by chance a shortage of the ones with dowels? I always thought these were the most common.
12/14/23       #6: Salice restricter clip for 110 degr ...
Doesn't sound right.
Is this the item number you are using?
C7R6AE9 = 110 degree, full overlay, soft close with dowels
12/14/23       #7: Salice restricter clip for 110 degr ...
Al
I just ordered the screw on but nothing with dowels. I ordered just what I needed but for future I would like the ones with dowels. They don’t seem to carry them. Might be worth checking into this.
12/14/23       #8: Salice restricter clip for 110 degr ...
Al,
Here are the Hafele item numbers. They have plenty of the doweled version in stock.
Dennis
View higher quality, full size image (644 X 205)
12/14/23       #9: Salice restricter clip for 110 degr ...
Al
12/14/23       #10: Salice restricter clip for 110 degr ...
They have 20,000 in stock with dowels. Please see my previous reply with the Hafele part numbers
12/14/23       #11: Salice restricter clip for 110 degr ...
Al
That number works. Don’t need 20,000 just 19,750!
Thanks Dennis
12/20/23       #12: Salice restricter clip for 110 degr ...
Scott Markwood
Thanks for providing excellent info as always, Dennis. BTW, the Hafele part number for the Salice S1E637XY clip is 329.24.501
Also, thanks for sharing the info about our doweled hinge inventory. We typically have plenty on hand and always more on the way, so if someone is seeing otherwise, they might want to give customer service a call. We have over 50 customer service reps trained and ready to serve.
12/20/23       #13: Salice restricter clip for 110 degr ...
Hi Scott,
Karen helped me with the details. Merry Christmas
12/20/23       #14: Salice restricter clip for 110 degr ...
Al
Scott,
I didn’t have number on hand. I typed in Salice soft close hinge 110 degree at top of page. It took me to the 110 soft close. There were four or five to choose from. The doweled ones were in faded print not in bold print. It would not let me order them. After Dennis gave me the number I typed that in and they came up. I called customer service and she said they would look into this glitch. I had the same problem in early summer.
If the A book is available I would like one, it had most of the products I use but my current copy is pre Covid.
12/21/23       #15: Salice restricter clip for 110 degr ...
Scott Markwood
Al, I totally understand. I'm not sure where we stand on A Books, but since they traditionally contain pricing, they are only distributed by our reps, so if you have a Hafele rep, reach out to them. If you don't have a Hafele rep, let customer service know and they'll connect you to a regional manager who can help you out. BTW, it's important to note that all of our reps are employees of Hafele America Co. and should be up to speed on all our catalogs and website details.
7/8/24       #16: Salice restricter clip for 110 degr ...
Al
Dennis and Scott,
I ordered fixing clips for Salice drawer slides. I have been using the ones with the flange. The number on bag ends with 007. I also needed the narrow clips which should have number ending 008. I received order from Hafele and bag with number 008 has the 007 clip in it. This is the bag from Salice so who or whatever picked it pulled the correct bag but part is in wrong bag. This may be an isolated incident but might be that the wrong part is widespread. I’m going to call later this morning but I think there is a chance I’ll get the wrong ones again. Thought I would bring this to your attention.
Al
