Subject: Re: Matching panels with hardwood
2/23/24
Jesse Beaverson Member
Website: https://instagram.com/jessebeaverson
So I have a big project coming up, all rift and quartered white oak. I was planning on using 1/4” white oak MDF for all my center panels in the doors, but the (sample) sheet I received looks nothing like the oak lumber I already bought. I am inclined not use solid wood center panels for movement reasons. Does anyone have any suggestions for me? I was considering vac bagging my own shop sawn veneer onto some MDF to get the matching right. Or should I just shop around for a different manufacturer for my sheets? Is it worth trying to stain the panels to match the wood frames? Any help is appreciated!
2/26/24       #2: Matching panels with hardwood ...
You can get a custom pressing done of sheets. The minimum in my area is six sheets. I am able to talk with the veneer supplier to select the veneer from photos or samples of the bundle. Talk to your board supplier.
I wouldn't saw my own veneer ever considering what is available commercially. How would you justify the massive increase in labor costs?
2/28/24       #3: Matching panels with hardwood ...
The MW Studio  Member
Website: themillworkstudio.com
I feel your pain with the mismatched samples. If you're up for it, trying your hand at vacuum bagging your own veneer onto MDF sounds like a cool DIY fix. Maybe shop around a bit more for sheets, you might get lucky. Staining is an option too, but it can be tricky. Best of luck sorting it out!
3/2/24       #4: Matching panels with hardwood ...
Does the lumber not match the panel?
Or does the panel not match the lumber?
I can't get a skid of white oak with any consistency is why I ask.
3/8/24       #5: Matching panels with hardwood ...
So I have various white oak (veneer, sheets, lumber) in the shop right now from like 7 different sources and none of it matches with any of it. I should’ve just made my own veneer from the start I think, or glued up solid panels. I tried a bunch of different stains as well and of course no magic solution there. Maybe there’s some supplier out there that I’ve yet to discover that could’ve solved this problem for me.
3/13/24       #6: Matching panels with hardwood ...
Bill Colligan Member
Since you are using rift white oak the wood movement will be minimal. Assuming you will be using a dull to flat sheen if you are staining I would do 3/8" around the panel prior to assembly. Use space balls to keep your panels centered and minimize the little that will be seen with seasonal movement.
