Subject: Re: White polyolefin glue for edgbanders
4/4/24
Oggie  Member
Does anyone know of any - WHITE - polyolefin glue that is made for edgebanding or at least that would work with edgebanders even if not designed for that in the first place (suitable melting temperature, viscosity, open time and such...)?
4/4/24       #2: White polyolefin glue for edgbander ...
Bozzy Member
Jowat 237.11
4/6/24       #3: White polyolefin glue for edgbander ...
Oggie  Member
Thank you Bozzy, but when I call Jowat representatives in the US they say "Not everything you see on Jowat (European) website is available in the US". Same with Kleiberit.
It looks like the common understanding of the rest of the world is that we do not need all the commodities they enjoy.
Anyway, if anyone knows of any such glue that is available here for purchase that would be great :)
4/6/24       #4: White polyolefin glue for edgbander ...
Bozzy Member
Oggie, just order it from a Canadian supplier for now. I'm sure the US suppliers will start carrying it soon.
https://www.tcstore.ca/jowat-toptherm-po-hot-melt-white-237-50-15kg-bag/
https://www.mckillican.com/finishing/adhesives-sealants/edgeband-hotmelt-adhes
ive/jowat-23711-jowat-toptherm-25-kg-bag/82123711/
4/9/24       #5: White polyolefin glue for edgbander ...
Oggie  Member
Bozzy, TC does not carry 237.11 and does not plan to. McKillican works only within a handful of states and FL is not one of them. They say "But we can sell it to you if you sit in a car and come here" :)
4/27/24       #6: White polyolefin glue for edgbander ...
Santiago Member
Have you used the 237.50? We have tried a 5lb container of it but I had issues with one specific wide edge-band and switched back to 280.30 once we ran out of the 5lb. But we decided to try again the 237.50, I just ordered a 33lb bag because the glue line was considerably better than the EVA. Any thoughts? Why do you want the white colored one? Do you have 2 pots to switch or will only run white all the time? We have a 2015 Homag and changing glue color is too time consuming to do it on a regular basis.
4/28/24       #7: White polyolefin glue for edgbander ...
Oggie  Member
Santiago,
Yes, we're using 237.50 regularly. For us it works better than EVA. We can adjust the glue line better/thinner, seems stronger, burns less, and we can almost get a board coming out clean without using scraping and buffing stations at our edgebander. It is also easier to clean.
Lately, we're seeing more interest in those high gloss white slab cabinet fronts and would like to have white glue there. Also, 99% of our cabinet cases are white melamine, so white glue would help there too.
We have two gluepots and would keep 237.50 in one and 237.11 in other.
If we had only one gluepot I don't think we would be switching colors on a regular basis, we would just stick with 237.50 for everything.
