Subject: Re: Pencil Sharpener
Pencil Sharpener
4/26/24
I found this to be much better than a .9 mm mechanical pencil
Look at the point on a #3 pencil
View higher quality, full size image (700 X 402)
https://toolsforworkingwood.com/store/item/MS-BWLPS2
4/26/24       #2: Pencil Sharpener ...
I'm not selling these, just that this is a really good solution to the "pencil" problem
4/29/24       #3: Pencil Sharpener ...
Keith Newton
Pat, have you ever tried to sharpen your pencils with a knife or chisel so the tip is somewhat chisel like with a thin wedge shape? This will give you a much finer line that will hold up longer than a round point.
Think of it as a mini carpenters pencil.
I recall when a new home center with the initials HD opened here, they were selling sharpeners that produced a round tip on flat carpenters pencils. I just had to leave the store shaking my head that someone in management didn’t even have a clue why carpenterd pencils are flat!
4/29/24       #4: Pencil Sharpener ...
Probably but IIRC it took too much time, admittedly the round point will not stay sharp long but it is super fast to put point back on the pencil and #3 pencil will stay sharp much longer than a #2 pencil.
I get tired of the mechanical pencils because of the problems of lead breaking or jamming or the nose getting loose.
4/29/24       #5: Pencil Sharpener ...
Oggie  Member
I use mechanical pencils of various thickness, e.g. .7mm, .9mm, 1.3 mm and (rarely) 2.0mm depending how rough is the surface. Sharpening on a piece of sanding paper. 1-2 strokes gives me flat blade-like tip for extra precise work. Lasts longer than the round tip point. The pen clip tells me which way the blade is oriented.
