Subject: Re: Omal Insert 1300
Omal Insert 1300
5/15/24
Cassie Member
Hello,
I am currently facing an issue with my Omal Insert 1300 machine this morning. When the machine is switched on, the PC is not automatically booting up, nothing appears on the LCD screen (no signal), nor does the usb dongle for the machine's program light up. I have to switch off the machine, open the doors, manually press the PC power button only then it will boot and LCD works.
I have cleaned out the machine, double-checked connections and the Event Viewer for the system doesn't show any glaring obvious answers.
Has anyone had this issue before? Is there a manual that I can check out ?
5/15/24       #3: Omal Insert 1300 ...
Matt Krig Member
Check the power supply to the PC inside the control box. We had the same thing on ours a couple years back.
Good Luck.
5/16/24       #4: Omal Insert 1300 ...
Cassie  Member
I had a look power supply and its in fine condition. What's even more bizarre is that when the side doors are left open and the machine is powered on, the pc boots up alongside the machine. But when you shut the machine down and then power it up with the doors closed, the PC won't boot at all.
I wish I could find a manual for this machine, I can't find anything on the web.
5/16/24       #5: Omal Insert 1300 ...
Steven Meyer
Hello,
Just a thought...
Check your the CMOS battery on your computer's motherboard.
We had a panel saw that behaved similarly...we had to manually start the PC whenever we powered on the machine. Replaced the battery, made sure the PC's BIOS was set to turn on computer when it received power. Problem was fixed.
5/17/24       #6: Omal Insert 1300 ...
Mick steele
Cassie, the battery is a possibility they should be changed about every 5 yrs. But as you can get it to boot up is not likely the issue. However regarding the door open/closed situation it appears you may have pinpointed the problem. The pc gets a safety signal input from the safety circuit, which may come from a safety module or direct from the individual safeties fitted. Dependent upon how the program is written the lack of safety circuit signal may shut you down completely. The doors will be fitted with sensors or mechanical/electrical switches. You can jump the switches out to determine if they are the issue, they are likely just 2 wire power in/power out. If you can trace the safety circuit to the pc you could just jump power to the pc safety circuit input. I am presuming it would be a 24vdc signal but maybe 110vac dependent upon the pc.
You may find it is money well spent to bring in a industrial electrician as the issue would seem to fairly simple to diagnose even without electrical schematics.
    • ECabinet Systems
    • GreCon
    • Western Dovetail
      Custom Made Dovetail Drawers
    • Texas Woodworking Festival
    • Air Handling Systems
