Subject: Re: Bead around slab door
6/1/24
Nick Cook Member
Website: http://kootenaicabinets.com
I'd like to place a bead around the outside edge of slab drawers and doors, they are paint grade. The image shows a mitered door below a slab drawer front. I'm trying to replicate the slab drawer front. It's not a router bit that was used due to the problem I'd have at the corners. I'm trying to figure out how it might have been done.
View higher quality, full size image (3840 X 2160)
6/1/24       #2: Bead around slab door ...
duster
I've done that detail before using a small trim router with an auxillary base and small fence clamped to it. It still required a bit of hand work with a small and sharp chisel to finish the inside corners. It's a little fussy to set up, but I think it was faster than making and applying a mitered molding.
6/3/24       #3: Bead around slab door ...
Nick Cook Member
Ok yeah, I guess there's no way to avoid handwork in the corners. Thanks for the info.
6/3/24       #4: Bead around slab door ...
Rich  Member
I would assume it was done on a CNC flat with 1/4 round bit.
