Subject: Re: Hinges for narrow stile full overlay cabinet doors
6/6/24
John B Member
Website: http://woodmanseewoodwrights.com
I have a job coming up that was priced with standard 5 piece wood doors, full overlay, with 2 1/4" width r&s. Now the Architect is requesting 1 1/2" width and I'm wondering if anyone even makes a concealed euro style adjustable hinge for this application. Blum makes a Mini that might work but not soft close. I would have to add soft close stops. Not thrilled with the smaller glue joint size also for door strength, I have some bigger doors. Anyone run into these yet? Seems to be a new trendy look.
6/7/24       #4: Hinges for narrow stile full overla ...
Jim Herron
Ive encountered a few nitwit designers of late pushing this
If they are capable of reason suggest a dead minimum 1-5/8" stile and rail width ( I know...they may jump in front of car at the suggestion)
I know theyre mathematically challenged but 35mm bore ( 1-3/8" plus 3mm tab ( 1/8" ) equals you punching just the inside edge of the stile and thru the panel face
I'd also highly recommend 1/2" panels with back rabbit and panels perimeter glued in place if using mdf or veneered mdfc panels
Most soft close hinges will require 14mm bore depth to function correctly
The latest is the narrow stile single oversized door split after assembly to make pair doors , thereby eliminating any structural integrity
Good luck
6/8/24       #5: Hinges for narrow stile full overla ...
Hello gentlemen,
I just thought I would jump in with some added info.
The Salice soft close Euro hinge has a 12mm deep cup and the soft close face frame hinge has an 11mm deep cup.
Have a great weekend.
Dennis Bean
Salice America
View higher quality, full size image (872 X 571)
6/8/24       #6: Hinges for narrow stile full overla ...
Yavuz
1 5/8 inches s/r members minimum for safe and sound.less than that size is risky and walk away in my book.
6/9/24       #7: Hinges for narrow stile full overla ...
Quicktrim
The way to achieve this look is with a 5/8 panel and a 3/16 applied moulding that wraps around the door edge .
Also you can do a 3/4 veneer panel with a 1/4 panel trim around the edge and use the k door hinges .
6/10/24       #8: Hinges for narrow stile full overla ...
I make 1" thick doors wrapped like Quicktrim is saying. ¾" panel with a rabbet around the perimeter making a tongue.
Edging/R&S has a groove in it to accept the tongue.
Drill as normal using a hinge that can handle a thick door.
I hate those f-ing doors. We're charging a ton for them, but they are time consuming and there's probably not as much margin as I'd like.
6/12/24       #9: Hinges for narrow stile full overla ...
Peter Rusterholz
Salice Air Hinge if they are willing to pay for it.
    • J&P Machines
    • CabMaster Software
    • Lignomat
