Subject: Re: 1432 Holz Her Edgebander Troubleshooting
2/23/18
Garen Pletzer
Hello,
I have a 1432 CP/B edgebander. Does anyone know where I can get a manual for this machine? Its a new machine to me but a 1999. Still learning never owned one. It ran great for 3 hrs then it poped this breaker. I turned it back on and about 15 min later it did it again. Its labeled 1940 Q2. Anyone have this machine or has any advice. I would greatly appreciate it.
View higher quality, full size image (2115 X 1986)
2/23/18       #2: 1432 Holz Her Edgebander Troublesho ...
JP Member
Those are motor starters/overloads. You could try turning up the yellow dial a bit. But typically that effects trips on startup.
You also might have a motor going bad and starting to draw too much current and therefore tripping the breaker. You could check amp draw to each phase of the motor it controls.
It should be pretty even across all phases.
2/23/18       #3: 1432 Holz Her Edgebander Troublesho ...
JP Member
I should add if the motor isn't pulling a crazy amount of amps. IDK what it typically pulls under 10 I would think.
You may just need to replace the starter in the pic.
Check the motor amp draw first though.
2/23/18       #4: 1432 Holz Her Edgebander Troublesho ...
Garen Pletzer
My thought they were the trim motors or the buff wheels in the pic. With this machine they aren't the high frequency motors. I picked up a volt meter so I will have to check it out. Thanks
2/23/18       #5: 1432 Holz Her Edgebander Troublesho ...
Dave L
Q2 is the feed motor. I had issues when its capacitor leaked. The conveyor does need to be cleaned and greased (special high pressure lithium) occasionally. Having the pressure bar/bridge to low could be another possibility, but that's hard to do unless someone (re)moved the white infeed block (.5mm gap between it and your stock).
2/26/18       #6: 1432 Holz Her Edgebander Troublesho ...
Eric  Member
Website: http://www.closetcity.com
I had a similar issue. Upon a close inspection of the station I found a piece of 2mm banding wedged between the blade and shroud. Was not big, but big enough to bind motor causing a breaker to pop. Look for the station that breaker number corresponds to e.g. 1918 is the end trimmers on mine.
Also look for a broken wire at the quick connection. Put a meter on each leg and make sure you have current at each side of breaker and at the motor.
2/26/18       #7: 1432 Holz Her Edgebander Troublesho ...
Dave L
My bad, there are two Q2's. 1940 Q2/K2/M2 is the bottom buffer motor (1435 Q2 is the feed motor). Assuming you're not overloading it (try backing it off), and connections are good, I'd try replacing the capacitor - any 4uf >220v motor run capacitor.
2/26/18       #8: 1432 Holz Her Edgebander Troublesho ...
Dave L
P.S. Thanks to Erick I got curious
1432 CP/B:
1435 basic machine
1971 edge feeder
1906 glue
1912 pressure
1973 end trimming
1975 flush trimming
1940 buffing
6/14/24       #10: 1432 Holz Her Edgebander Troublesho ...
Louis Callan
End trimmer saw keeps sticking. And cuts out .just happen now and then
    • J&P Machines
    • CabMaster Software
    • Lignomat
