Subject: Re: Black edgebanding
Black edgebanding
6/23/24
Jim Member
Hello
I have an old Edgebander (glue pot machine) which doesn’t do the best job of applying black 1mm banding to black laminate boards. Sometimes the glue is applied unevenly, either too much or too little. The result is you see the glue line in the black banding or you see parts of the banding where the glue is missing (sort of looks gappy). I don’t have the money for an expensive machine and 90 percent of the time it does an okay job.
Just wondering if any one has some tricks for touching up black banding? I’ve tried permanent texture and spirits which does okay, but it doesn’t solve the problem where there’s glue missing on parts of the banding. I’m thinking maybe a thin line of black putty but interested if anyone else has any suggestions.
6/23/24       #2: Black edgebanding ...
Bruce H
I'd take the machine apart and clean it. Re-adjust while putting it back together. I use black glue on black edgeband. Won't help it's gaped in places. I have a glue pot machine as well.
6/23/24       #3: Black edgebanding ...
Jim Member
Thanks for the response. The bander definitely needs an overhaul. Just wondering if there’s an interim solution to mask the damage
6/24/24       #4: Black edgebanding ...
Jim Herron
Maybe rent time on another shops edgebander?
