Subject: Re: uv coated drawer sides
7/11/24
Rodney Member
We currently purchase a uv coated baltic birch material and cut our drawer boxs on the a cnc router, just wondering anyone doing this if so how are they treating the raw edge? we are running them thru the edgebander but our bander is not the best... seems to leave some residue of glue on them that has to be cleaned very time consuming they are 1/2 thick, seem like the thinner material i cant get the bander to clean off as well, i seen an artical were somone was using a wax on the raw edges?
7/11/24       #2: uv coated drawer sides ...
Steven
I've used wipe on polyurethane. Wrap a cotton rag around finger, dip it in poly, and quickly wipe the box edges. Keep another rag and mineral spirits to wipe off any excess that runs down the UV sides. I wipe on 2 coats and done.
On some jobs we sand the cut edges with 320 grit paper on orbital sander. Maybe sand once more with 400 or 500 grit hand paper and no coating.
We run the top edge of sides through a bullnose bit or roundover.
Never tried wax.
7/14/24       #3: uv coated drawer sides ...
Jim Herron
I have used TreWax clear floor wax on Baltic birch 9ply after assembly
Honestly the 9 ply birch tails look good with nothing on them and great with anything on them
I normally use 4x8 unfinished to be sprayed but buy 12mm prefinished with a finished bulldoze top edge
I never have attempted banding the 12mm prefinished
    • CP Adhesives
    • ECabinet Systems
    • Cabinet Pro
    • Lignomat
    • Air Handling Systems
    • GreCon
    • INNERGY
