Subject: Re: Power Feeder Gearbox Oil
6/25/24
Michael
So I have a Pertici Univer 1800 four-wheel power feeder and I'm not sure what type of oil to put in. I have some synthetic automotive rear axle oil but I'm very hesitant about putting that in. The power feeder manual says to use AGIP RADULA 100 oil but I would have to go to Italy to get it and of course, you can't get it online.
So my question is should I use the synthetic automotive rear axle oil that I have or is there someone in this forum able to recommend an oil that will be safe?
Thanks group.
6/25/24       #2: Power Feeder Gearbox Oil ...
Ken Member
There's a saying, "The right oil is better then the wrong oil but the wrong oil is better then no oil" A quick search shows this to be a heavy petroleum based gear oil. I don't think you can go wrong with any gear oil. I just used some synth in the gearbox of my Rockwell 18 planer. Gear boxes tend to be slow rpm so I think you'd be fine.
6/25/24       #3: Power Feeder Gearbox Oil ...
Ken Member
https://energybp.com//upload/datasheet/radula100.pdf
6/26/24       #4: Power Feeder Gearbox Oil ...
Michael
Yes, I might be overthinking it. Thanks, Ken and for the kink!
7/24/24       #5: Power Feeder Gearbox Oil ...
Dan/drb
We use Lucas oil gear oil , it’s the clear one . Never had any problems in many different gear box’s including power feeders
