Subject: Re: need help with cutting dovetails in 1' x 1' sample eucalyptus plywood
8/14/24
Vadim Retter Member
Website: http://www.julielumber.com
RiseUp Industries
Dustin Greeves, Machine Shop Manager
d.greeves@riseupindustries.org
(619) 300-1314
Hello,
We are importers of hardwood plywood. Our main business has been birch. We started a new project with Paraguayan eucalyptus (urograndis) plywood this year.
I have 10 pcs of sample (1’ x 1’) 12 and 15mm throughout multiply eucalyptus plywood, and I need to cut dovetails on two sides to make joints. This is for testing only—just to prove that plywood is sufficiently sound for smooth dovetail cutting. Please shoot a video while cutting dovetails. I also plan to add one piece of sample birch plywood for test dovetail cutting to compare with cutting dovetails in eucalyptus.
I need this urgently and am ready to send you samples overnight.
Can anyone assist me? This is a small but urgent and critical request.
We are located in NJ.
Best regards,
Vadim Retter
Julie Lumber LLC
1 757 353-4749 ph
1 757 515-0404 m
1 757 525-2714 fax
v.retter@julielumber.com
www.julielumber.com
8/20/24       #2: need help with cutting dovetails in ...
Dovetails are not good joints for plywood due to the bidirectional nature of the wood product. Generally, when I see dovetails in plywood, I can only think “rookie” - not that there is anything wrong with starting out. Tongue and groove or lineal miter style t&g are great.
I understand you just want to make samples, but dovetails in plywood are not good examples.
8/20/24       #3: need help with cutting dovetails in ...
Vadim Retter
Thanks, David. We've been supplying Russian birch plywood to the cabinet industry for over 30 years, most of it has been used for drawer sides and would be dovetailed and UV-coated. We are trying to find the right substitutes where possible.
