Subject: Re: Leg levelors
Leg levelors
9/18/24
rich Member
Website: http://www.handmadefurniturecompany.com
We have recently decided to switch to using leg levelors as our default method for building kitchen cabinets. Not sure if there is any incite from the crowd of people who have been using them or used them and switched away, etc. One question that just came up here is on an inset kitchen we typically have an outside finished end have the frame extend down to the floor. In the current case there are cabinets, a range and cabinets. Given the open few inches below a range it seems that we need to close off the space under the cabinets right and left of the range. That would prevent the area under the cabinets from being exposed and collecting dust, etc. What is the general thought here on that sisuation?
9/21/24       #2: Leg levelors ...
Dave Edgerton  Member
We use hettich leg levellers and the attach kicks using clips. Yeswe close off the kickspace beside stoves and dishwashers bypin nailing a return kick. Then the front kickplate covers it. Im talking high end kitchens. If some appliance leaks and makes a mess, snap off the lick and replace. Easyfor access as well.
9/23/24       #3: Leg levelors ...
Daniel W Mazzone
Website: http://pedemontewoodworking.com
We typically cover that area with a full side panel that goes to the floor (if the design accommodates it) or do a mitered return kick at that area.
Separately, if you are just switching and buying into a new system: The Hafele Axilo legs are fantastic. They are adjustable with a tool that can easily reach the back of the cabinet, which makes it much simpler / quicker to level cabinets without lying down. There are screw on plates, press-in plates, lots of lengths, etc. I recommend them.
9/27/24       #4: Leg levelors ...
rich Member
Thanks, we are using the Hafele Axilo with the drill tool adjuster. We have now done a couple of kitchens and baths this month using the leg levelors. We aren't yet to the point of saying how could have ever done it any other way but so far so good.
    Lamello
    • Impact Search and Placement
    • The Millwork Studio
    • Cabnetware Support
    • CabinetCRUNCHER
    • J&P Machines
    • WalzCraft
