Subject: Re: KV 8092 Full Overlay pocket door
10/29/24
Mike D  Member
I'm trying out this system. Tired of the Accuride Pro-pocket not working correctly. Used that system for many years.
So I have my slides mounted on the inside of the pocket.
Any bright ideas how to access the hinges? Thought of a channel but that doesn't look great with the doors open.
Also thought of an oblong hole if I can find a cap that would fit.
What are others doing for this?
10/30/24       #2: KV 8092 Full Overlay pocket door ...
Sean Reynolds Member
Mike,
The KV8091 gives you a 3/4" overlay.
We used them once last fall. We cut access holes on the router, then used colored grommets to cover the holes. Not a fan of pocket doors, but these did the trick. We used magic wire shelf supports for the partition to slide in on,
then ran a screw in from below to keep it in place, our situation allowed for lower access. We also ordered deeper slides to allow the door to go deeper in the cabinet when open, (we had clearance depth wise to allow this). Sorry I don't have photos of the finished installation to post. We also had the allowance above and below to add to the doors, to keep all reveals the same. We did this by making the pocket door cabinet which was for a coffee maker on a long floor to ceiling bank of cabinets taller, allowing the doors above and below to layover the front of the frameless cabinet. sorry for the long drawn out explanation.
10/30/24       #3: KV 8092 Full Overlay pocket door ...
Mike D  Member
Appreciate the reply Sean. I'm thinking it has to be some sort of grommet as well.
Proper reveals lining up and wanting the unit to sit on a quartz counter are the big issues.
10/30/24       #4: KV 8092 Full Overlay pocket door ...
Sean Member
That was our issue also. The architect added that as we were in fabrication.
A little head scratching and the whole elevation being floor to ceiling helped us out to get all the reveals correct. Good luck with the project!
12/18/24       #5: KV 8092 Full Overlay pocket door ...
Christopher Tayler Member
If you call KV they will tell you where to mount the hinges for overlay. I just cant remember where that is. We only use that KV system, its bulletproof.
