Subject: Re: Marking/sawing/installing trims that are dark colors
12/24/24
Keith Farr
We prefinish and install our own cabinets. When we do black we have trouble seeing our pencil marks when cutting trims.
Is there any better marking pencils that can be seen on dark colors? All the white markers I've seen are not fine enough to do precision marking thts needed to cut molds.
Thanks for suggestions.
12/24/24       #2: Marking/sawing/installing trims tha ...
White pencil would work well.
Sharpies can be found in silver. I've never looked for white. I'm not sure how they perform on a dark color.
Chalk works.
For loose stiles and wood tops, I generally lay yellow tape down then put my scribe marks on the tape with a black pen.
12/26/24       #3: Marking/sawing/installing trims tha ...
Ryan Torok Member
I use a welding pencil that is called Silver Streak. They are softer lead but shows up well. Made in a standard wood pencil, or like a drafting mechanical version.
12/28/24       #4: Marking/sawing/installing trims tha ...
one thumb Member
Razor knife
    • Sandman Products
    • ECabinet Systems
    • Lignomat
    • RT Machine Co.
