Subject: Re: glue for hand re-gluing of 3 mil edgebanding
1/11/25
Eric R Smith
We have some 3 mil edgebanding coming loose. What is the best glue to use to squeeze in and tape shut while the glue dries? What will hold best?
Thank you for any help you can give us!
1/12/25       #2: glue for hand re-gluing of 3 mil ed ...
I suggest you tell us what material the edgebanding is made of. If run on an edgebander, you can probably use a hand iron and reactivate the glue.
1/12/25       #3: glue for hand re-gluing of 3 mil ed ...
Chris Campbell
We have been using 3M 90 high strength adhesive & Clamp(s). So far so good for the 3mm X 3/4" PVC banding to a 3/4" Particle Board core laminate door.
Why did it come loose... We found that due to the lack of, or very thin layer of glue in some spots along with the changing environmental conditions is what caused the separation. Thus a reheat of existing glue would be futile.
Good luck,
Chris
    • Sandman Products
    • ECabinet Systems
    • Lignomat
    • RT Machine Co.
