Subject: Re: 5 Ply Birch Indonesia Veneer Core 19mm / 3/4''
1/17/25
Michael
5 Ply Birch Indonesia Veneer Core 19mm. Has anybody heard of it? Is it any good? Thinking about trying it but I like to hear some support.
Thank you!
1/18/25       #2: 5 Ply Birch Indonesia Veneer Core 1 ...
Jim Herron
I have been using 18mm Indonesian white birch for several years both unfinished and UV cured prefinished for several years building frameless cabinet boxes.
Overall very pleased with it, and my customers seem to be satisfied with the end product as well.
I haven't seen it available in 19mm thickness, at least from my regular suppliers.
1/26/25       #3: 5 Ply Birch Indonesia Veneer Core 1 ...
Patrick Francis Drake Member
Website: http://www.carpconn.com
Good dust collection is needed.
1/29/25       #4: 5 Ply Birch Indonesia Veneer Core 1 ...
Mark
I had a problem with delamination and dimensional accuracy- i.e. thinner or thicker spots- on the same sheet, in both 3/4" & 1/2" It also would split if you put a screw into the plies, had to use a larger pilot drill and long screws in most cases.
The stuff was labeled from Vietnam.
1/29/25       #5: 5 Ply Birch Indonesia Veneer Core 1 ...
Jim Herron
The product I use is a calibrated core with white birch faces
Overall pleased with it.
I do get the rare sheet that has a glue skip in the plies, but it is readily apparent once it's ripped or crosscut.
I throw it out and my supplier issues credit on however many sheets I say it is, no questions asked.
It is quite rare, but any veneer core product is subject to the occasional glue skip, it's just the nature of manufacturing
