Subject: Re: Edgebanding narrow parts
2/1/25
Chris
Does anyone have a good solution for edgebanding both long edges on narrow strips (1-1/2"-2" wide)? If it's just one edge we will edge an oversized panel and rip afterwards, but this doesn't work when we need both edges banded.
We have a half decent Homag bander, but I think around 70mm is the minimum width
2/2/25       #2: Edgebanding narrow parts ...
Eric Z
We also need to do this from time to time. The solution I have come up with is to apply the edge to the oversized panel as you are doing, then rip to desired final size (minus edge band thickness), then tape the two parts together with the previously applied edges touching and the unbanded edges facing out. Now you have a 3" (2 x 1.5", for example) wide part to send through the machine and you can apply the edge to both sides of it. We run a continuous piece of masking or packing tape on BOTH sides of the seam to minimize movement. Using a Holzher here with a similar minimum width requirement.
2/3/25       #3: Edgebanding narrow parts ...
Bruce H
I saw this on you tube a while back and thought it might be something to remember. They used about a 5" wide board, thicker then the part they were edgbanding. Cut a rebate as deep as the part is thick and not quite as wide. So glue is not applied to the carrier board. The trick is if your upper pressure wheels contact the part you are wanting to edgband and hold it to the carrier board? I don't know what was done about the thickness now being more than your part or how it was being trimmed on the bottom. My guess is your edgband will need to be wider to make this work. I have no idea where I saw this so don't have a link.
    • Impact Search and Placement
    • Original Saw Company
      Industrial Radial Arm Saws
    • Western Dovetail
      Custom Made Dovetail Drawers
    • American Fabric Filter Co.
