Subject: Re: Recommendation for Touch Latch Pocket Doors
2/1/25
John McGinnis Member
I am looking for a recommendation for a good set of full height pocket doors that will use touch latch as the opening mechanism. I like the Salice Exedra but not sure if I can get it to work with PUSH system - maybe Dennis Bean can chime in on this? Thank you.
2/2/25       #2: Recommendation for Touch Latch Pock ...
Hello John,
Due to the nature of a pocket door movement, Push is not available. The door would need the handle to open the door then, then when pocketed into the cabinet, the soft close feature brings the door to a silent, smooth stop.
The handle would still be necessary to pull the door from the cabinet pocket. The soft close feature then returns the door to the closed position. Here is a short video illustration this.
If you still want to proceed with Excedra, please send the actual measurements of the door.
Attached also is an Excedra order form that we will use to determine the suitability of Excedra for your project.
We can send this form to you to complete.
Regards,
Dennis
View higher quality, full size image (1176 X 834)
Salice Excedra Pocket Door
2/3/25       #3: Recommendation for Touch Latch Pock ...
Thank you Dennis
    • Impact Search and Placement
    • Original Saw Company
      Industrial Radial Arm Saws
    • Western Dovetail
      Custom Made Dovetail Drawers
    • American Fabric Filter Co.
