Subject: Re: Floating vanities
Floating vanities
2/13/25
Good afternoon.
A client wants some floating vanities with 3cm thick quartz or granite tops.
I'm worried about them pulling off the wall. We typically make free standing vanities from prefinished import birch.
Any advice?
2/13/25       #2: Floating vanities ...
Jr Lee  Member
Website: http://www.leecabinets.com
Dropout I did this vanity 2 or 3 years ago. Quartz top. The customer had a friend that did countertops and installed it. There was a special metal support that was used to support the top but I don't know what it was but a confident quartz dealer should know.
View higher quality, full size image (5184 X 3456)
2/13/25       #3: Floating vanities ...
duster
I've done quite a few of these in the last 7 or 8 years. If it spans wall to wall, we'll screw the cabinet sides into the side walls, with shims to fill any gaps.
If one end of the cabinet or both aren't making contact with a wall, I've screwed steel L brackets to the studs to help support the weight from underneath.
Haven't had any failures with these methods.
View higher quality, full size image (800 X 471)
View higher quality, full size image (800 X 827)
2/13/25       #4: Floating vanities ...
Nathan Member
We do floating vanity all the time. We use Innova Shelf brackets. HDL carries them. They work amazing and never had any issues
View higher quality, full size image (1080 X 2340)
2/14/25       #5: Floating vanities ...
Another fad that needs to die.
We've been putting cabinets on the F-ing floor for a thousand years. But if it's different, it's gotta be better!!!
I run a ½" plywood back and a ¾" plywood nailer. I like to see them tagged to the wall with a ledgerlock. A piece of angle iron on the wall at the bottom is a good idea too. I also tell them not to fornicate on the counter.
2/14/25       #6: Floating vanities ...
Patrick Francis Drake Member
Website: http://www.carpconn.com
Do not 4N1k8! Great!
    • J&P Machines
    • CabMaster Software
    • Lignomat
