Subject: Re: cabinet door lift system
3/21/25
Sean Member
I am trying to find a lift system (blum aventos style) for a cabinet door that is about 32 X 32". The door only weighs 15lb but every system I look at says max height of 600mm max (24"). They also say they can lift up to 24kg (52lbs). surely with my door being so much lighter one of these would work? other than salice and blum are there other options here?
thanks!
3/21/25       #2: cabinet door lift system ...
I'd say get one that is rated for the most weight and give it a try. The issue is leverage and the longer the door the more leverage action it has at the pivot point. 15lbs is pretty lightweight and there's a good chance you can get it to work properly.
3/22/25       #3: cabinet door lift system ...
I agree with Leo about leverage being an important consideration. Before ordering, confirm with your supplier that you are able to return the hardware when you find out that it doesn’t work as you would like. These aren’t cheap.
Another solution would be to split the door into two 16” panels then use bifold lift hardware to fold the door upward.
3/22/25       #4: cabinet door lift system ...
Sean
Thanka fellas, i plan to order the most powerful and give it a go. Worth a shot. I feel pretty good about it.
    • Country Saw and Knife
    • ECabinet Systems
    • Anver Corporation
    • American Fabric Filter Co.
    • The Millwork Studio
