Subject: Re: Creating Slots as Parts in Cabinet Vision
4/25/25
Max Member
Hello folks,
I am a newbie to cabinetvision, looking to create a part that I can drop into an object to generate a rectangular slot for an outlet box, similar to a grommet hole. Any advice on how to do so? Thanks in advance!
4/30/25       #2: Creating Slots as Parts in Cabinet ...
John McGinnis Member
You cannot create a "part" that is just an operation that can be dropped onto another part but you can add operations to your parts very easily (even in a semi-automated way- if you are willing to do some work up front). take the cabinet to the assembly editor and then edit the part that you want to route. You can add operations in CAM tab.
5/1/25       #3: Creating Slots as Parts in Cabinet ...
Max Member
Hi John!
After looking into it some more, the way we sometimes add holes as parts is with an invisible hardware object, whose mounting hole is dimensioned for a grommet. Doesn't seem like that hole can be edited beyond its diameter though.
So I will look into your suggestion for making slots, thanks for your reply!
~Max
5/15/25       #4: Creating Slots as Parts in Cabinet ...
Max Member
For any interested, after further tinkering, I've found that custom geometry can be implemented for parts in this way. Editing the parts from the material manager will let you add any features normally available from the CAM tab for parts.
Used this feature to create the custom slots, so now they can be dragged and dropped in wherever on new parts without needing to redraw the slot geometry every time.
