Subject: Re: Grass Ecopress cycling too fast
7/29/25
Ryan Benny Member
I have grass ecopress that I have been using daily for over 10 years without issues until recently. Last week, out of the blue, it started to lower the press much faster than it ever did before, to the point where it stalls out the motor when the bit contacts the door. The bit has only been in it for a few weeks, so it is sharp. I have tried adjusting the main air regulator as well as the valve on the back of the machine that the manual says should adjust the feed rate but I can turn it all the way in or out and it makes no difference. I am out of ideas and I'm not even sure who to turn to in my area that would service it. Has anyone else had an issue like this?
8/1/25       #2: Grass Ecopress cycling too fast ...
Mitch Suber Member
Website: http://subercustomshutters.com
Ryan, I don't have an Ecopress, but your describing a similar problem I had on a Ritter inline drill. It's just a wild guess, but could it be a pneumatic cylinder problem? After years of use the rings and seals start leaking air, which creates secondary problems. My head on my drill started dropping too fast, then was extremely slow to rise back to a start position. I could see my drill bits were not drilling as quickly as usual, which puzzled me. I adjusted valves and everything I could think of to no avail. But after replacing my air cylinder everything started working correctly.
