Subject: Re: Crazy Question
Crazy Question
9/2/25
Jim Herron
I currently use Bosch 18v brushless impact drivers and I have two Bosch 18v drills.
While I love the impacts, the drills leave a LOT to be desired
Does anyone make a 1/2" cordless DRILL that does just that, DRILL?
I don't want driver/drill/hammer functions with adjustable clutch and speeds. Invariably while drilling, especially using hole saws for plumbing penetrations, the current models will either vibrate from drill mode to driver or hammer function or the clutch will unwind to its weakest setting.
I've yet to have a situation where I was thinking... "Gee, if only all this drilling could go slower!" or "@#&? it all!!".." This @#&$ torque is just too much!... if only this drill had less power"
Very, VERY, frustrating.
Any suggestions?
9/8/25       #2: Crazy Question ...
Walter Member
Bosch makes many non-hammer drill models. It might be hard to find one that does not have a clutch, but if you really don't want a clutch, just put the clutch in the highest, tightest position and it won't clutch at all. The Bosch website allows you to pick from non-hammer drills to see what they have available.
I have used DeWalt tools for years and never had a problem with either the hammer drill (which I use when I want a lot of speed) or the non-hammer drills.
9/8/25       #3: Crazy Question ...
Jim Herron
Sorry. I looked at their website. Only options is drill/driver or hammer drill/driver, both of which I own several. In use, the clutch moves under heavy load (think 3-4" inch hole saw) to a lower setting. I have used them being cognizant of the max setting and it invariably clutches down to a lower setting under load.
Who offers a cordless DRILL ONLY option, preferably in a 18+ voltage?
Thanks for the input.
9/8/25       #4: Crazy Question ...
Makita in their Compact class, that's just a drill.
I have a pile of them. I don't think anything makes them great, but they work fine for me.
I use to really like Panasonic stuff. Haven't looked at it in a long time. Still have a few drills and impacts that are 12 years old filling rolls in the shop
9/8/25       #5: Crazy Question ...
Jim Herron
Thank you Karl. I'll have a look.
One of my first cordless (right behind the Makita with the 5 inch 9.6volt battery) was a Panasonic
They were top rated in battery technology at the time.
