Subject: Re: Blum to Progressa
Blum to Progressa
10/25/25
Keith farr
Long time Blum guy but thinking about trying progressa. Is the hole in back same position as Blum? Could I pull out a set of Blum guides on an existing job, switch clips and guides and it still work?
10/25/25       #2: Blum to Progressa ...
Eric Z
Keith
I have used both systems extensively and yes- the rear hole placement is the same, along with the front and back drawer dimensions (interior width - 42 MM).
The height that the drawer sits at might be different by a few mm but you can just adjust the faces in the case of swapping them out.
The progressa+ (?) is a nice one with the added weight capacity along with the synchronized movement.
I do find Blum's side to side adjustment to be far superior though FWIW.
