Subject: Re: One piece MDF shaker style doors versus 5-piece
6/4/26
Gene Davis
Developents have occurred with CNC tooling and equipment so that a one-piece MDF door can be cut to look almost like a flat panel 5-piece shaker door. I've watched a video showing the three-bit sequence it takes to hog out the recess, then trim the perimeter of the recess, and finally to bevel that perimeter and pull the bit in a way that the corners look close to square. If you have bought and used these doors, how do they compare in cost, with the typical 5 piece doors made from paint grade wood stiles and rails and MDF centers? And how do the perform?
6/5/26       #2: One piece MDF shaker style doors ve ...
Leo G
They've also come up with a 2 pc CNC cut door. One of the problems with a one pc door is it can warp because of unevenness of the hogging out the front vs the read side. The 2 pc door solves that by cutting a frame with a rear rabbit which a panel is inserted into. Because the panel isn't cut on the face it remains stable. Only issue is it becomes a double sided process on the CNC.
I've used a few of these 2 pc doors but only as panels on refrigerators and DWs. So stability isn't really an issue since it's secured instead of hinged.
    • CabinetCRUNCHER
    • Cabnetware Support
    • O'Shea Lumber Company
      Merchants of Fine Woods
    • WOODWEB, Inc.
    • The Millwork Studio
