hinge for flip up bench
3/24/15
nicko
hi
i am looking for some kind of hinge for a bench with a flip up seat. i would like to use a continueous hinge but the ones that i have been looking for look like they install on the flat.
i need one to install between two peices of one inch wood with just the knuckle showing.
i thought i read the term reverse piano hinge somewhere. would that be what i need?
thanks......................nicko
3/24/15       #2: hinge for flip up bench ...
Joe Member
Try the SOSS Hinges. They mortise into the ends and you never see them They are very good hinges.
3/24/15       #3: hinge for flip up bench ...
Peter Rawlings
Plane Jane piano hinge will work, done many this way. Not sure what a reverse piano hinge is.
Soss is a more elegant solution and concealed if that's important.
3/24/15       #4: hinge for flip up bench ...
mike
Although I am not an expert on them I did need to do two this last yr. The 1st I did with a piano hinge and hafele lid stays. but for the second I was looking for a setup that had some adjustability so I used a std. blum 1/2 overlay hinge and it worked great. I have support all around so the hinge is not supporting the weight when it is closed. Although I used a soft close hinge it still closed to hard so I plan to go back to install a lid stay. I plan to keep using this system.
View higher quality, full size image (2304 X 1728)
3/24/15       #5: hinge for flip up bench ...
nicko
thanks Mike for posting the pics.
I need a hinge that install on the edge of two boards.
thanks.............nicko
3/25/15       #6: hinge for flip up bench ...
AzFred  Member
You probably want a toy box lid hinge. Most distributors of cabinet hardware carry such a thing.
This may not be what you had in mind but they were made for your application.
Toy Box Hinge
    Lamello
