Heavy shelves
8/21/15
Ron Shultz Member
I am designing a display case that will have 28" x 17" adjustable glass shelves 1/2" thick. There will be heavy art works placed on the shelves. Normally I linebore 5mm holes and use shelf pins for glass shelves. I'm worried about the weight of the shelves, etc tearing the shelf pins out of the display sides. Cabinet is built using 3/4" maple plywood.
Any ideas what I can do to strengthen the lineboring to support the weight? I've never used the sleeves you can buy for linebore holes. Do they add extra strength?
8/21/15       #2: Heavy shelves ...
Leo G
If you use the "L" shaped clips they will prevent the pins from coming out. Not really pretty, but sure will be safe.
View larger image
8/22/15       #3: Heavy shelves ...
Dan
282.24.733 is the item # for a Hafele shelf rest which has ribbed wedges which bite into your 5mm system hole. The shelf rest has a transparent rubber pad for glass and has a weight capacity of 110 lbs.
8/22/15       #4: Heavy shelves ...
AzFred  Member
Choices on the link page are available from local distributors nation wide or most woodworking catalogs.
Shelf Supports - Glass Shelves
8/22/15       #5: Heavy shelves ...
AzFred  Member
Another option is C.R. Laurance of Los Angeles and elsewhere. Specialist in hardware for glass
8/22/15       #6: Heavy shelves ...
D Brown
You could drill an extra row of holes on each end, I also have seen the use of a round acryilic
clear rod placed in the center of the shelf for support , didn't really show .
8/23/15       #7: Heavy shelves ...
Chris
I dunno guys, sure seems like the shear strength of a 5mm shelf pin would be more than a 16d nail. I once was a framing carpenter and was told that one 16d nail has a shear strength of roughly 120 lbs. given we used to walk on hips we were fitting with 2 16d "tacked" nails I'd say that's roughly correct. So...if there are 4 5mm pins?
8/24/15       #8: Heavy shelves ...
D Brown
A 16d nail or a 3" installation screw certainly has hundreds of pounds of shear strength but not when the nail only is in a 1/4 ".
    Lamello
