end panel toe notch
10/7/15
As I'm sure as most of you do, when a dishwasher is at the end of a run of cabinets we put a finished end panel in to support the countertop. Do you put a toe notch in that end panel?
10/8/15 #3: end panel toe notch ...
No. Straight to floor. It's bad design to have a skinny panel holding up a countertop in my opinion...unless the panel is quite thick and the connection solid.
10/10/15 #4: end panel toe notch ...
Straight to floor and we try to make it at least 1" or more. Harold.
10/14/15 #5: end panel toe notch ...
I've done it both ways. If the cabinet on the other side has a toe kick then I think it looks a little odd to not have a toe kick on the panel to match. Looks much better if we have done a base type foot and then get to extend the panel down as well.
2/20/16 #6: end panel toe notch ...
They don't call it a toe kick for nothing. Every time we leave it straight, I've have to go back and cut them in, because the people smash their toes on them. I now notch it on all of them , but only go about 2 1/4 in. That way the dishwasher toe doesn't stick out in front of it. MIKE
