Blum Dynaplan fix.
12/11/15
Jim Member
One man shop doing euro box contemporary high end (whatever that means).
Anyway for years I have been using Blums Dynaplan software to do the layout on my drawer boxes. Had it forever.After my computer updates I can no longer get it to load info. Blum does not support this program any longer.
Aside from Cabinetvision or one of the other all inclusive cabinet programs is there anything else out there that will do this at a reasonable cost. Some kind of drawer box program that would show the slide locations after you feed in the cabinet info?
12/12/15       #2: Blum Dynaplan fix. ...
james mcgrew Member
If you are looking for a box program look at cabinetpartspro.com I have used it for years and still do. I have had CW since 97 and CV (and most other software) a few years. I am learning cv to maybe change that but having a basic entry after setting parameters software has spoiled us.
12/12/15       #3: Blum Dynaplan fix. ...
james mcgrew Member
And I take it you are using a CNC ?
12/14/15       #4: Blum Dynaplan fix. ...
Jim Member
No CNC.
What now?
12/14/15       #5: Blum Dynaplan fix. ...
james mcgrew Member
What op system does it work well with,, Consider a dedicated computer ?
12/14/15       #6: Blum Dynaplan fix. ...
Gerry
I use the Dynaplan software and just downloaded version 3.4.43 recently as I was notified through the program that it was available. I have not seen any indication they are abandoning the program.
FWIW
Gerry
12/16/15       #7: Blum Dynaplan fix. ...
Jim Member
Thanks Gerry.
Had my rep contact Blum for me and they set me up with the upgrade. For some reason I wasn't getting them.
12/16/15       #8: Blum Dynaplan fix. ...
Gerry
Your welcome Jim good to hear you got it sorted out. I find the program invaluable to insure we are getting our hardware installed correctly.
Gerry
12/16/15       #9: Blum Dynaplan fix. ...
james mcgrew Member
I called our rep and after a call to Wilsonart was reffered to Blum e services online, anyone know where to get the upgrade ? it was more like a catalog.
12/16/15       #10: Blum Dynaplan fix. ...
Gerry
Hi James,
Try this link. Scroll down to Dynalog full version 370 MB.
http://www.blum.com/ca/en/02/40/10/
Gerry
12/16/15       #11: Blum Dynaplan fix. ...
james mcgrew Member
Thanks Gerry !
12/16/15       #12: Blum Dynaplan fix. ...
Gerry
Your welcome James.
Gerry
