oil spice pullout
4/15/16
Anybody have a good way to build a smooth oil/spice pullout with softclose?
4/17/16 #3: oil spice pullout ...
There are many ways to do it, but first you have to tell us the type you are doing... Upper cab, base cab, in-drawer pull-out, in-cab?...
View higher quality, full size image (1275 X 1650)
4/17/16 #4: oil spice pullout ...
I have bought base pullouts and I have built pullouts. Sometimes when you build these there seems to be a little bounce to the pullout. Its not smooth . This is why I'm putting this out to woodweb. To see if anyone has a way to build them were they are smooth.
4/17/16 #5: oil spice pullout ...
I like the Revashelf ones, smooth and good adjustment. They are for base cabinets.
4/17/16 #6: oil spice pullout ...
PJ... if you are worried about the bouncem then you need to use a glide at top also to stabilize... you can use side mounts but at the top and bottom, or you can use a side mount at the top and undermounts at the bottom (depending on how wide because of clips).., your defining factor seems to be soft-close AND no bounce... therefore, you can use the undermount soft-close with a loose sliding dovetail at the top OR you can use side-mount glides with soft close on top and bottom with a guide plug on the left/right...
Best of luck... 8^)
