Blum servo trash slide-out
6/1/16
Mark B
I've installed my first Blum servo trash slide out and it seems kind of finicky to operate?
I admittedly didn't understand where the second set of little spring cushions go and it seemed to work not as bad with only one set? Maybe that's my problem? Where should they be located?
Anyone have any experience or insight on this?
6/2/16       #2: Blum servo trash slide-out ...
David Thiessen  Member
Website: dtwoodworker.houzz.com
I locate my distance bumpers 2 5/16" down from the stretcher at the top and the same off the bottom . I also use the waste recycle set from Blum that comes with the tracks already connected and positions the Servo Drive exactly where it needs to be. I never have a problem .
6/2/16       #3: Blum servo trash slide-out ...
I should clarify that I position them centered on 2 5/16 from the top and bottom on the left and right of the opening. If you measure from the bottom up to the center of the bumper it should be 2 5/16" etc...
View higher quality, full size image (640 X 1138)
6/6/16       #4: Blum servo trash slide-out ...
Mark B
David,
Thanks for the detailed reply. That's not even close to what I did, so I'm anxious to try it. I'll be back at the jobsite later this week and will give it a go. Thanks again.
Mark
6/10/16       #6: Blum servo trash slide-out ...
Mark B
David,
Thank you again for the set-up info. I moved the bumpers as you described and it works great! I really appreciate your help.
Now if Blum could only learn to communicate as clearly as you instead of just drawing goofy pictures ... but that's another rant!
Mark
6/10/16       #7: Blum servo trash slide-out ...
Mark,
I am glad it worked out for you! In the future you might check with your supplier to see who your area Blum rep would be and get a hold of them. I am fortunate to have a really good one who has helped me many times with the installation of their products. But luckily we have a place like Woodweb to seek out help from our fellow cabinetmakers as well!
    Lamello
