Panel Genie
euro hinges for glass doors
8/17/16
John E.
Website: http://mountainhomecabinetcompany.com
My glass supplier says that the tempering process requires a tab that is twice the dimension of the glass thickness. Is there a hinge that will work with a 1/2" (12.7mm) tab?
Thanks, John
8/18/16       #2: euro hinges for glass doors ...
John,
I am not familiar with any glass door hinges like what you describe that can be used with glass over 1/4" (6mm 1/4" TAB).
Salice does offer a hinge that attaches to the surface of the glass by means of a UV adhesive. There is no drilling of the glass required.
Here is a product bulletin for the Vetro hinge.
View higher quality, full size image (1228 X 1676)
8/18/16       #3: euro hinges for glass doors ...
John E.
Thanks Dennis.
I will look into it.
Thanks, John
8/18/16       #4: euro hinges for glass doors ...
I seem to recall seeing a Grass hinge that could be used with 3/8" thick glass but I can't seem to locate it anywhere now. Maybe I was just dreaming on that.
    Lamello
