Wood shaper info
10/9/16
I was looking at purchasing a used shaper if I can find a decent one? I was thinking I should get an SCM if I can find one, or any other recommendations?
How far back should a guy go for a used one? Are the green color SCM ones any good?
Thanks everyone!
10/10/16       #2: Wood shaper info ...
What do you want to do with the shaper?
10/10/16       #3: Wood shaper info ...
JeffD
The SCM shapers are very good quality with a nice heavy build. Finding a decent one is not all that difficult, just a matter of narrowing it down to what you want and what you want to pay. They range from an entry level T-100, to the very common T-110's, and the heavy T-130's and tilting T-160s. I have several European machines and all are from the "green" era. Good quality stuff!
Of course there are many other quality manufacturers as well. So expanding your search should yield a lot of possibilities!
good luck,
JeffD
10/10/16       #4: Wood shaper info ...
Bill,
The main function of the shaper will be to build 5 piece cabinet doors.
10/10/16       #5: Wood shaper info ...
I thought you just bought one.
10/10/16       #6: Wood shaper info ...
Rich,
Ya I bought one a few years ago, I looked at the name of it and it is pioneer. I was told that I should get 2 of them and leave them set up. But I am starting to think maybe just 1 good one as I am not sure of the pioneer. I will check it out tomorrow.
10/11/16       #7: Wood shaper info ...
You have considered that making doors with one shaper is not very efficient and you would likely be better off buying them?
10/11/16       #8: Wood shaper info ...
If the Pioneer has a big enough spindle, put a raised panel cutter on it. Then get another shaper with a long enough spindle to stack the cope and stick sets on the one spindle. But, I sourced the doors all the time. Place the order, and they'll almost show up before you get the boxes all done.
    • Better Vacuum Cups, Inc.
    • Biesse America
    • CP Adhesives
    • Impact Search and Placement
    • Template Services
