shelf pin problem
4/17/17
Jim Member
Got a large open shelving cabinet (no doors) and one of the line bores is off a BIG sixteenth. Has anybody seen or heard of shelf pins that are not concentric with the hole? Maybe one you could turn a little bit to make up for the alignment mistake?
Or any ideas for a fix. Thanks.
4/17/17       #2: shelf pin problem ...
Josh Koschak Member
Could you make a matching interior wall to reskin the existing out of 1/4" mdf core plywood?
4/17/17       #3: shelf pin problem ...
Mike Member
Could you plug the holes and re-drill by hand and use the metal sleeve supports to hide the plug line?
4/17/17       #4: shelf pin problem ...
Alan F.
Rabbet or groove one end of the shelf so it drops down 1/8", do the same on the other end for 1/16", use the round pins
4/17/17       #5: shelf pin problem ...
JeffD
Closest I know of is the using the basic pins with a flat support surface. I've had a cabinet or two that was off a little in the old days and found by turning one of the pins upside down, or if really bad two opposite corners, they would just make up for a little drilling error.
Not ideal and wouldn't want to do it on a nice piece, but it can work in a pinch.
good luck,
JeffD
4/17/17       #6: shelf pin problem ...
Jeff is talking about the metal spoon style pins. They were the typical ones for face frame cabinets. Normally 1/4". They are also available in 5mm. They suit your problem.
4/17/17       #7: shelf pin problem ...
Leo G
What about putting a small dado in the shelf that takes up the space of the offset of the pin. That assumes the pin is high by a big 1/16" and not low.
4/17/17       #8: shelf pin problem ...
Hen Bob Member
I 2nd JeffD, or Alan and Leo's response if you can
4/17/17       #9: shelf pin problem ...
Mark V.
Is
this is what you are looking for?
4/17/17       #10: shelf pin problem ...
Matt Calnen
I have had that problem once. I solved it by using the "L" shaped shelf pins and bending the part the shelf rests on up a little on the two low holes. I call it Irish-American engineering. From that day on I always double check my machine.
4/18/17       #11: shelf pin problem ...
Rich Kuban Member
Website: http://www.closetexperts.com
JeffD's answer has worked for me. Additionally, you could try some different clear adhesive door bumpers to find the best thickness to handle the gap on the low corner.
4/18/17       #12: shelf pin problem ...
Richard
I haven't used these and they are available from different sources.
https://www.amazon.com/Platte-River-156194-Hardware-Support/dp/B00887N
3OC
4/18/17       #13: shelf pin problem ...
Jim Member
Thanks for all the responses.
I guess sometimes your just to close to the problem to see the solution.
I was already using the metal spoon type pins. Turned 2 of them over on opposite corners and problem solved. And it's not even noticeable that they are turned over.
Thanks to all.
4/20/17       #14: shelf pin problem ...
Bruce H
I likes Hen Bob and Richard's eccentric shelf pins. Didn't know they were available. Good find guys.
    Lamello
