why not get them cut from the CNC shop. Work out the maximum size that would work for you and get a good material yield.
Order a lot at a time. On a quiet day edge them all at once and put them into stock.
You could then cut them down and use them when you need them. If they are always the same size just order them exactly the size you need, even better!!!
Don't let your age or your workers limitations stop you from buying a CNC. You could get a second hand CNC, train one of your guys to use it and easily lose a worker or alternatively boost production. CNC much cheaper than 1 x skilled worker, never takes sick days, does what you ask, no backchat or getting a different result from what you asked for. Let's you control how things are being cut and put together and saves issues down the line.
When I bought our CNC I bought brand new, because even thought I'm switched on with computers I had never run a CNC more than press the go button and unload the parts. I'm thankful that I did, but now that I know how it all works I wouldn't hesitate buying a second hand unit for the great saving you would get.
When everyone has gone home for the day I give mine a pat on the back and thank it for a good days work. I couldn't be bothered getting out of bed in the morning if it wasn't in the shop!
