Panel Genie
Negative angle concealed hinge
9/2/17
Mark B
Does anyone know of a concealed hinge that would work with the door configuration as shown ....
Angled_HInge.pdf
9/2/17       #2: Negative angle concealed hinge ...
eddie Member
Look at pg 53-54in the blum hinge book. They have negative hinges. from -5 to -45 degree. I did not open your pdf. So I am not sure if these will work.
9/3/17       #3: Negative angle concealed hinge ...
Hey Mark,
Here is a Salice drawing. The part numbers show a self closing hinge with dowels and a 0mm mounting plate for wood screws. Euro screws are also available.
C2RBH99 - Minus 45 degree hinge, self close with dowels
BAR3R09 - 0mm mounting plate for wood screws
BARGR09/16 - 0mm mounting plate with pre-attached Euro screws.
Good luck,
Dennis
CAD_C2RBH99_BAR3R09_D11_K4_5_T19.pdf
View higher quality, full size image (1190 X 1631)
View higher quality, full size image (1106 X 265)
9/5/17       #4: Negative angle concealed hinge ...
Russell Member
Mark,
I have used the Blum -45deg. hinge #79B3490 which functions very much like the Salice hinge shown in the drawing that Dennis provided. However, that is for an overlay application instead of inset the way you are looking for. You should be able to make an inset door, but the hinged edge will have to be perpendicular to the face instead of beveled as shown in your drawing and you will need to be inset to a decorative strip instead of the side panel of the cabinet.
9/5/17       #5: Negative angle concealed hinge ...
Russell,
You're right. I was looking at the angle at the right of the drawing (in blue) showing an overlay -45.
Dennis
    Lamello
