Lamello lipping planer
6/5/18
Kevin Member
Anybody out there using one of these? I'm considering purchasing one but not sure if I need the parallel guide stop. It says it is to be used for melamine and finished surfaces. Is this required for just trimming solid wood on veneered ply? The plywood is not pre finished. Thanks
6/5/18       #2: Lamello lipping planer ...
MB
I have the Adler/Hoffman lipping planer. I probably only use it once a month or so, but when I do, it's great!
Assuming the Lamello is similar, I don't know why you'd need a parallel guide if you're using it to flush trim.
6/6/18       #3: Lamello lipping planer ...
Joe Otto
Website: http://joescustomcabinetry.com
I bought one ten years ago and didn't opt for the fence. Never have needed it. This little machine has saved many hundreds of hours.
6/6/18       #4: Lamello lipping planer ...
Chris
Website: http://www.csaw.com/lamello/specialty-machines/can...
Kevin,
For your application, the parallel guide is not necessary. I demo the Cantex all the time without it. Because the micro height adjustment of the cutter is so accurate (.004" per click of the dial), you can mike the height in right where you need it to be and the cutterhead will float above the substrate. My customers who use the parallel guide do so typically when they want to plane solid wood edging slightly deeper when it's applied to a laminate surface, so that when they apply the finish to the wood, the thickness of the finish is co-planar with the surface of panel. Keep it in mind if you have a project where you may need it, but for your application you'll be fine without it. Just make yourself up a practice blank and play around with the height adjustments at first and then it's a breeze and you'll love. My favorite machine - I used to do all my solid wood edging with a pattern bit and a router - wish I had known about it! Machine is a no-brainer if you do a lot of solid edging.
It's not the cheapest, but it's the world's best by a mile and it'll last you the rest of your career.
6/6/18       #5: Lamello lipping planer ...
Chris H
Sorry, typo in my last reply. It's .0014", not .004" per click of the adjustment dial on the Cantex. That's 1/35mm or about half the thickness of a human hair. Thanks Joe, for your input, I actually shared that with a couple of customers I just demoed the Cantex for here in the Syracuse area today!
6/6/18       #6: Lamello lipping planer ...
Kevin Member
Thanks for all the responses. Ordered one this morning.
6/6/18       #7: Lamello lipping planer ...
Chris H
Kevin,
Great! You won't be disappointed!
Thank you,
Chris
