Pneumatic stapler for Melamine assembly
1/22/19
matt
Asking to see if anyone can suggest a QUALITY pneumatic stapler for production of 3/4" melamine cabinetry. Staples just hold the carcase together until we get screws in it.
18 gauge, 1/4" crown, 1-1/4" staples.
We build 10-30 cabinets a day so it will get quite a lot of use.
The reason I'm asking is because we've found over the years that an actual GOOD stapler for melamine is a crap shoot. If I find a model that works great, the next one I buy might not actually set the staples deep enough in melamine, consistently...... regardless of how you adjust it.
We've tried pretty much all the major brands (Dewalt, Porter Cable, MAX, Senco to name a few) and have found the same inconsistency among them.
Even the best among them seem to last a year or two before things wear out to the point that even a rebuild doesn't seem to put them back to where they set staples consistently.
Incoming air pressure is 95psi.
1/22/19       #2: Pneumatic stapler for Melamine asse ...
Long time ago when I was working for others they would staple the melamine boxes together, didn't bother with screws.
I believe they were using a 1/2" crown by 2" long staple. Never seen them have problems with their guns.
1/22/19       #3: Pneumatic stapler for Melamine asse ...
matt
That wouldn't work in our situation. I know the sort of staples you're talking about and you are correct that they are quite strong.
We actually do use a few of those here (1/2" crown 16 gauge staple) in the shop for various purposes. But they wouldn't work for us for cabinet assembly, we'll definitely need the screws to finish them off.
1/22/19       #4: Pneumatic stapler for Melamine asse ...
I've got a Hitachi 1/4" crown stapler that work pretty well. Use it to put 1/2" backs on cabinets. But it's max capacity is 1 1/2" for length.
N 3B04AB3(S) Is what's on the nameplate.
Hitachi N 3B04AB3(S) Stapler
1/22/19       #5: Pneumatic stapler for Melamine asse ...
I believe the top stapler and brad nailer made these days according to my tool suppliers is made by Omer, they have a 1 9/16 x 1/4 inch stapler. I was thinking of trying their brad nailers but they are quite expensive compared to my fleet of Airy ones that I like. I can't find parts any more so may have to take the plunge.
1/22/19       #6: Pneumatic stapler for Melamine asse ...
matt
Anyone using the Senco SKS? They run around $300 but supposedly are built to perform, and last. We haven't tried that one yet, maybe we should.
1/22/19       #7: Pneumatic stapler for Melamine asse ...
Jim Herron
I use confirmat assembly for my frameless boxes, and use a Paslode 16ga stapler to tack them together, using 1/2" crown x 2", followed by driving the confirms in all the pre bored holes.
Works very well.
Forget the 1/4" crown guns, especially on melamine, as it will deflect or wrinkle the 18ga staples.
I also use it to staple my 18mm backs in place, no need to use screws there.
The 16 gauge guns are built to install roof decking, and therefore see a high volume of staples run thru them.
1/22/19       #8: Pneumatic stapler for Melamine asse ...
Cabinetmaker
We have 14 sks senco staplers
They won’t take the abuse of dropping off the bench like they used to. But say to replace drivers
1/23/19       #9: Pneumatic stapler for Melamine asse ...
Stewart Member
I have a couple of senco sks staplers that we have abused for about 20 years now - still going strong!
1/23/19       #10: Pneumatic stapler for Melamine asse ...
Tom
I find the SKS to work well in MCP as long as you use Senco brand staples in it. The cheaper brand staples will work in ply but not MCP
1/24/19       #11: Pneumatic stapler for Melamine asse ...
Jeff Mills
We used to use staples, but switched to brads and havent thought of going back. Unless you need to shuffle the cabinet across multiple benches during the staple/screw process, the brads hold just fine until you can get the screws in.
    • Doucet Machineries Inc.
    • WOODWEB, Inc.
    • WalzCraft
    • Limtech Industries, Inc.
    • Sandman Products
